Ana içeriğe geç
LG Front Load Washing Machine Pressure Sensor Replacement
Neye ihtiyacın var
  1. LG Front Load Washing Machine Pressure Sensor Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement, Safety Precautions: adım 1, 2 resimden 2.
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    FixBot'a Sor
    Yorum Ekle
  2. LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the top panel: adım 2, 3 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the top panel: adım 2, 3 resimden 2. LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    FixBot'a Sor
    Yorum Ekle
  3. LG Front Load Washing Machine Pressure Sensor Replacement, Remove the top panel: adım 3, 2 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement, Remove the top panel: adım 3, 2 resimden 2.
    • Slide the top panel towards the rear of the device to disconnect its clips.
    FixBot'a Sor
    Yorum Ekle
  4. LG Front Load Washing Machine Pressure Sensor Replacement: adım 4, 2 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement: adım 4, 2 resimden 2.
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    FixBot'a Sor
    Yorum Ekle
  5. LG Front Load Washing Machine Pressure Sensor Replacement, Disconnect the pressure sensor: adım 5, 2 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement, Disconnect the pressure sensor: adım 5, 2 resimden 2.
    • Depending on your device, your pressure sensor might have a wire harness. If so, disconnect each wire on the harness.
    • Disconnect the connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
    FixBot'a Sor
    Yorum Ekle
  6. LG Front Load Washing Machine Pressure Sensor Replacement: adım 6, 2 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement: adım 6, 2 resimden 2.
    • Disconnect the hose from the pressure sensor.
    FixBot'a Sor
    Yorum Ekle
  7. LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the pressure sensor: adım 7, 1 resimden 1.
    • Remove the screw(s) securing the pressure sensor.
    FixBot'a Sor
    Yorum Ekle
  8. LG Front Load Washing Machine Pressure Sensor Replacement, Remove the pressure sensor: adım 8, 3 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement, Remove the pressure sensor: adım 8, 3 resimden 2. LG Front Load Washing Machine Pressure Sensor Replacement, Remove the pressure sensor: adım 8, 3 resimden 3.
    • Unclip the pressure sensor from the chassis or other components.
    FixBot'a Sor
    Yorum Ekle
  9. LG Front Load Washing Machine Pressure Sensor Replacement: adım 9, 2 resimden 1. LG Front Load Washing Machine Pressure Sensor Replacement: adım 9, 2 resimden 2.
    • Lift the pressure sensor away chassis and remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
Bill Gilbert
39.917 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.572 adet Kılavuz yazıldı
4Kılavuz Yorumları
Would this sensor also be responsible for an oe error. Drain line is clear and pump removes most of the water. The machine then continues to cycle through spin and drain with very little water coming out. When I remove the emergency drain line, it only has a couple cups of water in it.
Lg tromm front load washer.
Fred Becker - Yanıt Paylaş
I am having the same problem and I think that is my issue but am not sure.
John Hughes - Yanıt Paylaş
Hi Fred (and John), sorry for the long wait! Yes, that sensor could be responsible, but the tube is often plugged. The machine tries to pump itself out because the sensor is still getting a full signal from trapped air because of a clog in the tube that can act like a check valve. Sometimes, this pressure will bleed off over time, and the machine will stop trying to run a perennial drain cycle. Take a look at this part of the LG washing machine troubleshooting sheet. Even though it is for "no water," the same system is involved.
Bill Gilbert - Yanıt Paylaş
I just wanted to say I have been battling my LG front loading washer for the better part of a week and couldn’t get that pesky OE code to go away. I replaced the drain pump motor and checked for clogs in all the hoses except for the hose to that water pressure sensor. This advice was an absolute godsend, thank you so much. I was getting very close to looking at a new machine. After opening it back up again and taking out that hose it turns out that was what the issue ended up being. Now my washing machine runs like new! thanks again!
maxim pariset - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 46
Son 30 gün: 166
Her zaman: 4,524
