Ana içeriğe geç
Lenovo 100s Chromebook-11IBY Battery Replacement
Neye ihtiyacın var
  1. Lenovo 100s Chromebook-11IBY Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 3, 2 resimden 1. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 3, 2 resimden 2.
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 4, 2 resimden 1. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 4, 2 resimden 2.
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 5, 1 resimden 1.
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 6, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Battery Replacement: adım 7, 1 resimden 1.
    • Remove the battery.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 farklı kişi bu kılavuzu tamamladı.
Milton Perez
630 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S7G2
1 Üye
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 2,377
