Ana içeriğe geç
Lenovo Edge 15 Battery Replacement
Cody Griffith
Cody Griffith ve 2 diğer katkıda bulunanlar
En son January 2, 2018 tarihinde güncellendi
4 dakika
Kolay
This guide will give you a step-by-step process for replacing the battery on the Lenovo Edge 15 laptop. You will need to remove the back-cover first. Caution: If battery is leaking do not touch it with your hands.
Neye ihtiyacın var
Aletler
  1. Lenovo Edge 15 Battery Replacement, Battery: adım 1, 2 resimden 1. Lenovo Edge 15 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the eleven M2 x 6.0mm back-cover screws.
    • Unscrew the screws using the Phillips #0 screwdriver.
    • If battery is leaking, do not touch with bare hands.
  2. Lenovo Edge 15 Battery Replacement: adım 2, 2 resimden 1. Lenovo Edge 15 Battery Replacement: adım 2, 2 resimden 2.
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Battery Replacement: adım 3, 3 resimden 1. Lenovo Edge 15 Battery Replacement: adım 3, 3 resimden 2. Lenovo Edge 15 Battery Replacement: adım 3, 3 resimden 3.
    • Locate the battery-connector and the three, M2 x 4.0mm screws holding the battery in place.
    • Carefully unplug the battery-connector, wiggling the connector side to side if needed.
    • Unscrew the 3-screws using the Phillips # 0 screwdriver.
  4. Lenovo Edge 15 Battery Replacement: adım 4, 2 resimden 1. Lenovo Edge 15 Battery Replacement: adım 4, 2 resimden 2.
    • Gently lift all four corners of the battery to remove it from the laptop.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Cody Griffith
369 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S8-G1, Banghart Fall 2017 Cal Poly, Team S8-G1, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S8G1
5 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Can I recharge a fully drained battery by reseating it?
Linda - Yanıt
My laptop caught on fire don't recommend
Rahem Gang - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 152
Her zaman: 9,153
