Ana içeriğe geç
Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement
Jonathan Baldo
Jonathan Baldo ve 3 diğer katkıda bulunanlar
En son December 30, 2024 tarihinde güncellendi
30 dakika
Orta
Topluluk-Katkılı Kılavuz
This is a touchpad removal guide for the Lenovo IdeaPad Flex 5 14ARE05. The touchpad is the built-in device that's responsible for your mouse input to the laptop. In this guide, you will remove the back panel, battery, and motherboard to reach the touchpad. If your touchpad is not functional or needs to be replaced for any other reason, use this guide. Make sure the laptop is powered down and disconnected from all power sources.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 2, 3 resimden 3.
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 3, 1 resimden 1.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Battery: adım 4, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the four 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 5, 2 resimden 2.
    • Rotate the device 90 degrees.
    • Gently lift up on the battery and use a spudger to disconnect the battery connector.
  6. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Cooling Fan: adım 6, 1 resimden 1.
    • Remove the four 2 mm screws using a JIS #1 screwdriver.
    • Remove the three 5 mm screws using a JIS #1 screwdriver.
  7. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 7, 3 resimden 1. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 7, 3 resimden 2. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 7, 3 resimden 3.
    • Unplug the wire at the bottom right of the fan.
    • Carefully lift the fan from its place.
  8. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement, Touchpad: adım 8, 1 resimden 1.
    • Pull on the blue tab to disconnect the large ribbon cable.
    • Pull on the blue tab to disconnect the small ribbon cable.
  9. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 9, 1 resimden 1.
    • Use the spudger to disconnect the speaker plug on the right of the motherboard.
    • Pull the speaker towards you and it will disconnect from its mount.
    • Pull up on the Wi-Fi card wire connections, and move them aside.
  10. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 10, 1 resimden 1.
    • Remove the four 4 mm motherboard screws with a Phillips #1 screwdriver.
  11. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 11, 1 resimden 1.
    • Remove the two 2 mm screws from the right hinge using a Phillips #2 screwdriver.
    • Disconnect the screen cable connector.
    • Remove the motherboard from the laptop.
  12. Lenovo IdeaPad Flex 5 14ARE05 Touchpad Replacement: adım 12, 1 resimden 1.
    • Remove the four 2 mm screws from the touch-pad bracket using a Phillips #0 screwdriver.
    • Pull the bracket up and out of the frame of the laptop.
Sonuç
Jonathan Baldo
319 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Konn Fall 2024 UMass Dartmouth, Team 1-6, Konn Fall 2024 üyesi
UMASSD-KONN-F24S1G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 134
