Ana içeriğe geç
Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 3, 2 resimden 2.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: adım 4, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: adım 4, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, Battery Disconnect: adım 4, 3 resimden 3.
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: adım 5, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: adım 5, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement, M.2 SSD: adım 5, 3 resimden 3.
    • Remove the single 2.9 mm screw holding down the solid state drive with a Phillips #0 screwdriver.
    • The SSD will rise to rest at an angle once the screw is removed.
  6. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 6, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 6, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 M.2 SSD Replacement: adım 6, 3 resimden 3.
    • Pull the solid state drive out of its port to the right at a similar angle to which it rests.
    • Remove the SSD from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Blakely
21.336 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.657 adet Kılavuz yazıldı
1Rehber Yorum
Very informative, the pictures were most helpful.
IDK if you've got a guide detailing the drive cloning process or not but that would put the icing on the cake.
Thank you
FaQue Microsoft - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 87
Her zaman: 6,679
