Ana içeriğe geç
Lenovo IdeaPad Flex 5-1570 RAM Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 2, 3 resimden 3.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 3, 2 resimden 2.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: adım 4, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: adım 4, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: adım 4, 3 resimden 3.
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: adım 5, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: adım 5, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Push the two tabs on both sides of the RAM stick apart to release the memory module.
    • The RAM will rise up to rest at an angle to the motherboard.
  6. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 6, 3 resimden 1. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 6, 3 resimden 2. Lenovo IdeaPad Flex 5-1570 RAM Replacement: adım 6, 3 resimden 3.
    • Pull the RAM stick out of its port with respect to the angle at which it rests.
    • Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Austin Blakely
21.336 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.657 adet Kılavuz yazıldı
4Kılavuz Yorumları
I've had a Lenovo Flex 5 for a number of years and it has been extremally reliable. I wasn't aware that upgrading anything on this unit was even possible. Thank you for this info, I'll be checking into this more.
John - Yanıt
Please suggest what DDR4 RAM I should buy to replace it. I have a 16 GB, I want to go 32 or 64.
Maulik Darji - Yanıt
"Patriot Viper Steel DDR4 32GB 2400MHz CL15 SODIMM Memory Module PVS432G240C5S" works on mine
Finality Video -
Thank you for posting this and especially to the commentor that posted the memory upgrade info. This has been a great laptop and I look for to extending the life of it with this upgrade.
Vee - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 88
Her zaman: 10,412
