Lenovo IdeaPad y510p Network Card Replacement
Giriş
1. adıma gitThis replacement requires small Phillips head screwdrivers. It is also recommended to research if the replacement card will work with the laptop, as only certain cards are compatible. And, as when taking apart any sensitive electronics, be sure to touch something metal to remove any static charge you may have accumulated.
Neye ihtiyacın var
Aletler
Slide the left battery lock to the left
While holding the right battery lock to the right, pull the battery out.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Steps to White list the Newly installed network card in the BIOS. Follow Steps : http://www.thecosmosphere.com/how-to-rem...
I used the Intel Centrino Advanced-N 6235 6235ANHMW Wlan Bluetooth 4.0 Half MINI Card 802.11 a/b/g/n Dual-band 300 Mbps as replacement.
