Ana içeriğe geç
Lenovo IdeaPad y510p Network Card Replacement
Alex  David
Alex David ve 5 diğer katkıda bulunanlar
En son May 16, 2024 tarihinde güncellendi
20 dakika
Kolay
This replacement requires small Phillips head screwdrivers. It is also recommended to research if the replacement card will work with the laptop, as only certain cards are compatible. And, as when taking apart any sensitive electronics, be sure to touch something metal to remove any static charge you may have accumulated.
Neye ihtiyacın var
Aletler
  1. Lenovo IdeaPad y510p Network Card Replacement, Network Card: adım 1, 2 resimden 1. Lenovo IdeaPad y510p Network Card Replacement, Network Card: adım 1, 2 resimden 2.
    • Slide the left battery lock to the left
    • While holding the right battery lock to the right, pull the battery out.
  2. Lenovo IdeaPad y510p Network Card Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad y510p Network Card Replacement: adım 2, 2 resimden 2.
    • Slide the disk drive lock up.
    • While holding the lock in the middle of the laptop up, remove the disk drive
  3. Lenovo IdeaPad y510p Network Card Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad y510p Network Card Replacement: adım 3, 2 resimden 2.
    • Unscrew all nine of the backplate screws with a #0 Phillips screwdriver.
  4. Lenovo IdeaPad y510p Network Card Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad y510p Network Card Replacement: adım 4, 2 resimden 2.
    • Carefully pry the backplate off of the laptop.
  5. Lenovo IdeaPad y510p Network Card Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad y510p Network Card Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad y510p Network Card Replacement: adım 5, 3 resimden 3.
    • Pry the wireless antenna connectors off of the network card.
    • Be careful not to damage the connectors on the wireless card.
  6. Lenovo IdeaPad y510p Network Card Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad y510p Network Card Replacement: adım 6, 2 resimden 2.
    • Unscrew the screw holding the network card in place with a #0 Phillips screwdriver
  7. Lenovo IdeaPad y510p Network Card Replacement: adım 7, 1 resimden 1.
    • Slide the network card out of the connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alex David
173 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Steps to White list the Newly installed network card in the BIOS. Follow Steps : http://www.thecosmosphere.com/how-to-rem...
I used the Intel Centrino Advanced-N 6235 6235ANHMW Wlan Bluetooth 4.0 Half MINI Card 802.11 a/b/g/n Dual-band 300 Mbps as replacement.
Amazon : https://www.amazon.com/gp/product/B009SJ...
John Santhosh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 2,664
