Ana içeriğe geç
Lenovo Ideapad 320-15IAP Battery Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: adım 1, 2 resimden 1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: adım 2, 1 resimden 1.
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: adım 3, 1 resimden 1.
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: adım 4, 2 resimden 1. Lenovo Ideapad 320-15IAP Battery Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: adım 5, 2 resimden 1. Lenovo Ideapad 320-15IAP Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 45
Her zaman: 1,202
