Ana içeriğe geç
Lenovo Legion Y520-15IKBN Battery Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y520-15IKBN Battery  Replacement, Base Panel: adım 1, 2 resimden 1. Lenovo Legion Y520-15IKBN Battery  Replacement, Base Panel: adım 1, 2 resimden 2.
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Battery  Replacement: adım 2, 1 resimden 1.
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Battery  Replacement, Battery: adım 3, 2 resimden 1. Lenovo Legion Y520-15IKBN Battery  Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  4. Lenovo Legion Y520-15IKBN Battery  Replacement: adım 4, 2 resimden 1. Lenovo Legion Y520-15IKBN Battery  Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  5. Lenovo Legion Y520-15IKBN Battery  Replacement: adım 5, 1 resimden 1.
    • Lift the battery up and out of the chassis.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Thank you, very helpful.
ska Smith - Yanıt
I’ve damaged mine at step 4 and i don’t know how. Now the plug is loose and at the slightest touch, it goes into failure…I don’t now how to solve this, maybe replace the socket on the board by a new one. :(
Ricardo Peixoto - Yanıt
Hello
I dont know if you are gonna read this, but you could try to glue the connector with Superglue to the board, but watch out to not tear it off or put superglue into the connector.
electro -
Has anyone had issues with Legion Y520 laptop saying that the "battery isn't recognized" (with the x through it via the icon in the taskbar) after swapping the battery? I have tried three different ones that all do the same thing (one is even an OEM Lenovo Legion Y520 battery). I am thinking that either, the machine wants it to be an OEM one (not a third party one) and has some sort of check done after POST to verify if it is an official battery or not (and the one I have is just DOA?) or that there is an issue with the connector on the board itself?
mewdew64 - Yanıt
I did change the battery and he was charging ton100%. I ttok out de ac psu an d directly dead. When i put the ac psu one the system it works fin, how come?\
Nico Stam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 121
Son 30 gün: 278
Her zaman: 24,153
