Ana içeriğe geç
Lenovo Legion Y520-15IKBN Heatsink Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y520-15IKBN Heatsink Replacement, Base Panel: adım 1, 2 resimden 1. Lenovo Legion Y520-15IKBN Heatsink Replacement, Base Panel: adım 1, 2 resimden 2.
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 2, 1 resimden 1.
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: adım 3, 3 resimden 1. Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: adım 3, 3 resimden 2. Lenovo Legion Y520-15IKBN Heatsink Replacement, Fan: adım 3, 3 resimden 3.
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 4, 3 resimden 1. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 4, 3 resimden 2. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 4, 3 resimden 3.
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 5, 3 resimden 1. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 5, 3 resimden 2. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 5, 3 resimden 3.
    • Lift the fan out of the laptop body.
  6. Lenovo Legion Y520-15IKBN Heatsink Replacement, Heatsink: adım 6, 2 resimden 1. Lenovo Legion Y520-15IKBN Heatsink Replacement, Heatsink: adım 6, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the five 6.5 mm screws securing the heat sink.
  7. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 7, 2 resimden 1. Lenovo Legion Y520-15IKBN Heatsink Replacement: adım 7, 2 resimden 2.
    • Use a spudger to gently pry the heatsink from the board.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uriel Meneses
85 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 262
