Ana içeriğe geç
Lenovo Legion Y530-15ICH Fan Replacement
Neye ihtiyacın var
  1. Lenovo Legion Y530-15ICH Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Fan Replacement: adım 2, 2 resimden 1. Lenovo Legion Y530-15ICH Fan Replacement: adım 2, 2 resimden 2.
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Fan Replacement, Fan: adım 3, 2 resimden 1. Lenovo Legion Y530-15ICH Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
    There were 6 holding the heat sink on when I did it.
    Bryce Christensen - Yanıt
  4. Lenovo Legion Y530-15ICH Fan Replacement: adım 4, 1 resimden 1.
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  5. Lenovo Legion Y530-15ICH Fan Replacement: adım 5, 1 resimden 1.
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  6. Lenovo Legion Y530-15ICH Fan Replacement: adım 6, 2 resimden 1. Lenovo Legion Y530-15ICH Fan Replacement: adım 6, 2 resimden 2.
    • Lift the fans out of their positions and remove them from the device.
    Don't forget to pick up thermal paste so you get a good contact between the CPU and GPU and the heat sinks!
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kaylie Klausing
776 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G1
4 Üyeler
12 adet Kılavuz yazıldı
4Kılavuz Yorumları
Thank you! Very clear and well photographed :)
Daniel Perez - Yanıt
Any recommended stores for the replacement fans?
Ivan Ramljak - Yanıt
Worked like a charm, thank you!!
Skyler Boyle - Yanıt
where can i get a good replacement please
peters pelumi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 34
Son 30 gün: 150
Her zaman: 14,349
