Ana içeriğe geç
Lenovo Legion Y530-15ICH Fan Replacement
Kaylie Klausing
Kaylie Klausing ve 4 diğer katkıda bulunanlar
En son September 28, 2023 tarihinde güncellendi
10 dakika
Kolay
Replacing faulty fans is essential to keeping your computer’s insides working. This guide details how to remove the fans to either clean or replace them to ensure the processor does not overheat.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo Legion Y530-15ICH Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Fan Replacement: adım 2, 2 resimden 1. Lenovo Legion Y530-15ICH Fan Replacement: adım 2, 2 resimden 2.
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Fan Replacement, Fan: adım 3, 2 resimden 1. Lenovo Legion Y530-15ICH Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
    There were 6 holding the heat sink on when I did it.
    Bryce Christensen - Yanıt
  4. Lenovo Legion Y530-15ICH Fan Replacement: adım 4, 1 resimden 1.
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  5. Lenovo Legion Y530-15ICH Fan Replacement: adım 5, 1 resimden 1.
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  6. Lenovo Legion Y530-15ICH Fan Replacement: adım 6, 2 resimden 1. Lenovo Legion Y530-15ICH Fan Replacement: adım 6, 2 resimden 2.
    • Lift the fans out of their positions and remove them from the device.
    Don't forget to pick up thermal paste so you get a good contact between the CPU and GPU and the heat sinks!
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kaylie Klausing
776 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G1
4 Üyeler
12 adet Kılavuz yazıldı
4Kılavuz Yorumları
Thank you! Very clear and well photographed :)
Daniel Perez - Yanıt
Any recommended stores for the replacement fans?
Ivan Ramljak - Yanıt
Worked like a charm, thank you!!
Skyler Boyle - Yanıt
where can i get a good replacement please
peters pelumi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 35
Son 30 gün: 151
Her zaman: 14,356
