Ana içeriğe geç
Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement
Lawrence Lam
Lawrence Lam ve 3 diğer katkıda bulunanlar
En son January 17, 2025 tarihinde güncellendi
10 - 15 dakika
Kolay
Are you having network problems or internet lag when you work or play games when you purchased your Lenovo Legion Y7000P-1060? No worries, this guide will show you the step to carefully disassemble your laptop to take and replace the network chip so you can upgrade or replace with a new one. The Lenovo Legion Y7000P-1060’s stock network chip is notorious for their awful wifi/network chip that comes in the laptop. People usually upgrade or replace it since it is below expectations.
Neye ihtiyacın var
  1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 3.
    • Using the Phillips #00 screws, remove 13 screws from the backside of the laptop.
    • Five 2x1/2 screws.
    • Eight 1x1/2 screws.
  2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Pry open the back cover open with a plastic opening tool.
  3. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 3, 2 resimden 1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Carefully remove the taped on paper under the fans.
  4. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 4, 3 resimden 1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 4, 3 resimden 2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 4, 3 resimden 3.
    • Remove the four screws that are holding the battery down using a Phillips #00 screwdriver.
    • Disconnect and remove the battery from the device.
  5. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 5, 3 resimden 1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 5, 3 resimden 2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 5, 3 resimden 3.
    • Using a plastic opening tool, carefully disconnect the two cables connected to the Wi-Fi card.
  6. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 6, 3 resimden 1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 6, 3 resimden 2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: adım 6, 3 resimden 3.
    • Using the Phillips #00 screwdriver, remove the screw holding the Wi-Fi card to the device.
    • Remove the Wi-Fi Card from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lawrence Lam
204 İtibar
1 Kılavuz yazıldı
3 Yorum
Thanks for the guide Lawrence, can I ask what card you replaced the stock one with?
mkrnblack - Yanıt
I reccomend using the Wireless AC 8265 with bluetooth. There is the one I bought:
Intel Dual Band Wireless-Ac 8265... https://www.amazon.com/dp/B01MZA1AB2?ref...
Hope it goes well for you, it should fix all the ping spikes and unstable internet from the stock lenovo wifi chip.
Lawrence Lam -
Thanks for the recommendation I originally went with the 9560.NGWG.NV but It was not an improvement, in fact it might be worse. So I will try the 8265.
mkrnblack - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 128
Her zaman: 1,667
