Ana içeriğe geç
Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Prepare your laptop for disassembly: adım 1, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Prepare your laptop for disassembly: adım 1, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Prepare your laptop for disassembly: adım 1, 3 resimden 3.
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Loosen the base cover screws: adım 2, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Loosen the base cover screws: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Pry up the base cover: adım 3, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Pry up the base cover: adım 3, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Pry up the base cover: adım 3, 3 resimden 3.
    • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
    • Pry up the base cover until the clips unfasten.
  4. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the base cover: adım 4, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the base cover: adım 4, 2 resimden 2.
    • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
    • Lift and remove the base cover.
    • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
  5. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Loosen the battery screws: adım 5, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Loosen the battery screws: adım 5, 2 resimden 2.
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
  6. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the battery: adım 6, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the battery: adım 6, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Lift the edge of the battery with the connector to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
    • Remove the battery
    • During reassembly:
    • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
    • Lower the battery into place so the connector goes over its socket.
  7. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Disconnect the ribbon cable: adım 7, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Disconnect the ribbon cable: adım 7, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Disconnect the ribbon cable: adım 7, 3 resimden 3.
    • Use a spudger or your fingernail to flip up the locking flap on the NFC cable ZIF connector.
    • Use your fingers or tweezers to pull the cable out of its connector.
  8. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Disconnect the trackpad cable: adım 8, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Disconnect the trackpad cable: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to lift the trackpad cable connector straight up and out of its socket on the NFC reader board.
    • Don't pull on the cable—only insert your tool under the connector.
  9. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Pry up the NFC reader: adım 9, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Pry up the NFC reader: adım 9, 2 resimden 2.
    • Slide the flat edge of an opening pick under the NFC reader board and pry up to separate the adhesive securing it.
  10. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the NFC reader: adım 10, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the NFC reader: adım 10, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 NFC Reader Replacement, Remove the NFC reader: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $2.99
    • Grab the NFC reader by its edges and pull up to separate the remaining adhesive.
    • Remove the NFC reader from your laptop.
    • If your replacement part does not include new adhesive, use thin, double-sided tape to secure it to the chassis.
    • During reassembly, ensure you place your replacement NFC reader in the same position as the original, with the ZIF connector facing the motherboard and the press connector facing its cable.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Nick Schultz
19.174 İtibar
113 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.543 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 303
