Ana içeriğe geç
Lenovo ThinkPad T16 Gen 3 Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Prepare your laptop for disassembly: adım 1, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Prepare your laptop for disassembly: adım 1, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Prepare your laptop for disassembly: adım 1, 3 resimden 3.
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Loosen the base cover screws: adım 2, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Loosen the base cover screws: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Pry up the base cover: adım 3, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Pry up the base cover: adım 3, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Pry up the base cover: adım 3, 3 resimden 3.
    • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
    • Pry up the base cover until the clips unfasten.
  4. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the base cover: adım 4, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the base cover: adım 4, 2 resimden 2.
    • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
    • Lift and remove the base cover.
    • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
  5. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Loosen the battery screws: adım 5, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Loosen the battery screws: adım 5, 2 resimden 2.
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
  6. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the battery: adım 6, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the battery: adım 6, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Lift the edge of the battery with the connector to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
    • Remove the battery
    • During reassembly:
    • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
    • Lower the battery into place so the connector goes over its socket.
  7. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Disconnect the camera cable: adım 7, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Disconnect the camera cable: adım 7, 2 resimden 2.
    • Use the flat end of a spudger or clean fingernail to gently push under the metal buckle of the camera cable connector to unclip it
  8. Lenovo ThinkPad T16 Gen 3 Screen Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement: adım 8, 2 resimden 2.
    • Grab the buckle and cable together and gently pull the connector straight out of its socket.
  9. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the camera cable: adım 9, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the camera cable: adım 9, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the camera cable: adım 9, 3 resimden 3.
    • Hold the buckle and cable together and free it from the clips holding it to the fan.
  10. Lenovo ThinkPad T16 Gen 3 Screen Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 Screen Replacement: adım 10, 3 resimden 3.
    • Continue freeing the cable until it is only attached to the laptop at the hinge.
  11. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Disconnect display cable: adım 11, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Disconnect display cable: adım 11, 2 resimden 2.
    • Use a clean fingernail or the flat end of a spudger to gently push under and lift the metal buckle of the display cable connector to unclip it
  12. Lenovo ThinkPad T16 Gen 3 Screen Replacement: adım 12, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement: adım 12, 2 resimden 2.
    • Grab the buckle with your fingers and gently pull the connector straight out of its socket.
  13. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the display cable: adım 13, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the display cable: adım 13, 2 resimden 2.
    • Hold the buckle and cable together and pull it up to separate the adhesive securing the cable to the motherboard.
  14. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Disconnect the WiFi antennas: adım 14, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Disconnect the WiFi antennas: adım 14, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Disconnect the WiFi antennas: adım 14, 3 resimden 3.
    • Insert an arm of your angled tweezers under the metal neck of one of the coaxial connectors on the Wi-Fi card and lift straight up to disconnect it.
    • Repeat for the other connector.
    • During reassembly, use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  15. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the Wi-Fi antennas: adım 15, 3 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the Wi-Fi antennas: adım 15, 3 resimden 2. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Free the Wi-Fi antennas: adım 15, 3 resimden 3.
    • Grab both Wi-Fi antenna cables and guide them out of their clips on the frame until they're only attached to your laptop at the hinge.
  16. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Open the screen completely: adım 16, 1 resimden 1.
    • Open your laptop 180 degrees (so it's completely flat) and lay it keyboard side down on your work surface.
    • Optionally, you can place a soft, clean cloth under your laptop to protect the screen and keyboard.
  17. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the hinge screws: adım 17, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the hinge screws: adım 17, 2 resimden 2.
    • Use a Phillips screwdriver to remove the six 6.5 mm‑long screws securing the hinges to the laptop.
  18. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the screen assembly: adım 18, 2 resimden 1. Lenovo ThinkPad T16 Gen 3 Screen Replacement, Remove the screen assembly: adım 18, 2 resimden 2.
    • Lift the screen assembly straight up and remove it from the laptop.
    • Reassembly steps:
    • Make sure the screen hinges are open 180 degrees and guide them into their recesses in the frame.
    • Install and partially tighten the four hinge screws.
    • Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
    • Fully tighten the hinge screws.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Nick Schultz
15.802 İtibar
87 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.481 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 45
Her zaman: 300
