Giriş
Follow this guide to replace the WWAN card in your Lenovo ThinkPad T16 Gen 3 laptop.
The WWAN (Wireless Wide Area Network) card allows you to connect to the internet using a cellular connection. If your computer has a WWAN card installed and you're having trouble using cellular, you may have a faulty WWAN card.
If you are having trouble accessing a local Wi-Fi connection, you may have an issue with your WLAN card, which cannot be replaced independently of the motherboard on this laptop.
The Lenovo part number for the WWAN card is 5W11H85459 for the 5G model and 5W11H85427 for the LTE model. This guide works for both, with the exception of antenna count (two for LTE and four for 5G as shown in this guide).
Neye ihtiyacın var
Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
Pry up the base cover until the clips unfasten.
Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
Lift and remove the base cover.
Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
Lift the edge of the battery with the connector to disconnect it.
Remove the battery
Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
Lower the battery into place so the connector goes over its socket.
Insert one arm of your angled tweezers under the metal neck of one of the antenna coaxial connectors on the WWAN card and lift straight up to disconnect it.
Use a Phillips screwdriver to remove the 4 mm‑long screw securing the WWAN card to the motherboard.
Use your fingernail to lift up the WWAN card enough to grasp it with your fingers.
Pull the WWAN card away from its socket.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove thermal pad backings from the new part before you install it.
