Ana içeriğe geç
Lenovo ThinkPad T431S Fan Replacement
Joe Minnich
Joe Minnich ve 4 diğer katkıda bulunanlar
En son June 3, 2020 tarihinde güncellendi
10 dakika
Orta
This guide will show you how to locate and replace the Lenovo T431s fan. The cooling fan is what keeps your processing unit cool so the elements of your computer don’t overheat. If you are experiencing malfunction, overheat warning messages, or hot components, you might need to replace your cooling fan.
Neye ihtiyacın var
Aletler
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: adım 1, 2 resimden 1. Lenovo ThinkPad T431S Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T431S Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T431S Fan Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T431S Fan Replacement: adım 3, 3 resimden 3.
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 388
