Ana içeriğe geç
Lenovo ThinkPad T460s Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T460s Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Battery Replacement: adım 2, 1 resimden 1.
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Battery Replacement: adım 3, 1 resimden 1.
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    Make sure to pull only the white part. I had some difficulty disconnecting mine and got confused, thinking I was doing the wrong thing.
    Michael Wu - Yanıt
  4. Lenovo ThinkPad T460s Battery Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T460s Battery Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T460s Battery Replacement: adım 4, 3 resimden 3.
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
    My replacement battery didn’t come with a replacement black tape tab.
    Michael Wu - Yanıt
    Same here - I just used the one from the old battery
    Martijn Graumans -
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 farklı kişi bu kılavuzu tamamladı.
13Kılavuz Yorumları
I have a question, please. Are the two batteries identical?
Felipe L.R. - Yanıt
No, the batteries are different.
Battery 1 Part Number: 00HW022. (23.510 mWh)
Battery 2 Part Number: 01AV405. (26.330 mWh)
Best regards!
Rafael -
Hi there, anyone know which battery is number 1? - only battery 1 is broken in my laptop, 2 still works.
Jonas Andersen - Yanıt
Hello!!?? Any in iFixit knows the answer to Jonas’ question???
Ruben -
Battery 1 is 00HW022. (23.510 mWh)
Battery 2 is 01AV405. (26.330 mWh)
You can confirm it by yourself running powercfg /batteryreport on cmd
Hope it helps!
Rafael -
For Windows: Battery 1, the "rear battery", is under the touchpad. Battery 2, the "front battery" is near the display hinges.
Windows Bat 1 = Linux Bat 0. Windows Bat 2 = Linux Bat 1.
Rear battery P/N: 00HW022, 00HW023, 01AV406, 01AV407, SB10F46463.
Front battery P/N: 00HW024,00HW025, 00HW038, 01AV405, 01AV406,SB10F46476, SB10J79003, SB10J79004.
Lee -
The parts list for this article includes the replacement REAR battery for the T460s, which can be bought through iFixit. Does anyone know where one can buy the replacement FRONT battery?
Spencer Rosengarten - Yanıt
Both batteries can be found on Amazon. Whether the batteries are reliable or not, it's hard to say.
johnsgchurchill -
thank you very much .. this is use full
hillaryshereni001 - Yanıt
Ciao qual'è la 1 e qual'è la 2 batteria?
Bruno Armiento - Yanıt
How long will a brand new battery last.
Bismark Opoku - Yanıt
My Laptops Both Battery was excellent condition. Suddenly for 10 days My Battery 1 isn't Charging ( Screenshot ). What can I Do Now?
Asif Shahnaoaz - Yanıt
Hello, i have a question regarding this battery. My CPU Fan stops working when I plug in this battery. It works ok with the other one and when plugged in into the charger.
Martin Stainer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 108
Son 30 gün: 514
Her zaman: 54,551
