Ana içeriğe geç
Lenovo ThinkPad T470 WLAN Antennas Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T470 WLAN Antennas Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement, External Battery: adım 1, 3 resimden 3.
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 2, 3 resimden 3.
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 WLAN Antennas Replacement, Internal Components: adım 3, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, Internal Components: adım 3, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 4, 2 resimden 2.
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 5, 2 resimden 2.
    • Place your fingers on the bottom edge of the keyboard.
    • Use a small amount of pressure to push the keyboard towards the screen.
  6. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 6, 3 resimden 3.
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  7. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
  8. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 8, 2 resimden 2.
    • Use your hands to lift the keyboard up and away from the laptop.
  9. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 9, 1 resimden 1.
    • Close the laptop's lid and flip the laptop over so that the bottom is facing upwards.
  10. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 10, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 10, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 10, 3 resimden 3.
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  11. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 11, 1 resimden 1.
    • Remove the bottom cover from the laptop.
  12. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 12, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 12, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove two 5 mm screws from the internal battery.
  13. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 13, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 13, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 13, 3 resimden 3.
    • Use your hands to lift the battery up and away from the laptop.
  14. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 14, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 14, 2 resimden 2.
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  15. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 15, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 15, 2 resimden 2.
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  16. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 16, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 16, 2 resimden 2.
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  17. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 17, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 17, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 17, 3 resimden 3.
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
  18. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 18, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 18, 2 resimden 2.
  19. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 19, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 19, 2 resimden 2.
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  20. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 20, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 20, 2 resimden 2.
    • Use the flat end of a spudger to separate the connector from its socket.
  21. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 21, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 21, 2 resimden 2.
    • Grab the tab on the left side of the hard drive, and pull up to remove it from the laptop.
  22. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 22, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 22, 2 resimden 2.
    • Use a finger to press the black flap covering the Wi-Fi card down.
  23. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 23, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 23, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 23, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the left and the black wire on the right.
  24. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 24, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 24, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
  25. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 25, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 25, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 25, 3 resimden 3.
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
  26. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 26, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 26, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
  27. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 27, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 27, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 27, 3 resimden 3.
    • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
  28. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 28, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 28, 2 resimden 2.
    • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
  29. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 29, 1 resimden 1.
    • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
  30. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 30, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 30, 2 resimden 2.
    • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
    • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
  31. Lenovo ThinkPad T470 WLAN Antennas Replacement, Motherboard: adım 31, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, Motherboard: adım 31, 2 resimden 2.
    • Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
  32. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 32, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 32, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the LCD cable from its socket on the motherboard.
  33. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 33, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 33, 2 resimden 2.
    • Use the flat end of a spudger to flip the power button cable's black tab up.
  34. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 34, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 34, 2 resimden 2.
    • Use the flat end of a spudger to slide the power button cable out of its connector on the motherboard.
  35. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 35, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 35, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 35, 3 resimden 3.
    • Use your fingers to detach the red and blue antenna cables from their slots.
  36. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 36, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 36, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the USB bracket.
  37. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 37, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 37, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 37, 3 resimden 3.
    • Use your fingers to lift the USB bracket up and away from the laptop.
  38. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 38, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 38, 2 resimden 2.
    Satın Al
    • Use a pair of blunt nose tweezers to disconnect the DC-in cable from its socket on the motherboard.
  39. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 39, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 39, 2 resimden 2.
    • Use the flat end of a spudger to flip up the metal bracket securing the camera cable to the motherboard.
  40. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 40, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 40, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the camera cable from its socket on the motherboard.
  41. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 41, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 41, 2 resimden 2.
    • Use a pair of blunt nose tweezers to disconnect the speaker cable from its socket on the motherboard.
  42. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 42, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 42, 2 resimden 2.
    • Use the flat end of a spudger to flip up the black tabs on the trackpad and fingerprint reader cables.
  43. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 43, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 43, 2 resimden 2.
    • Use a pair of blunt nose tweezers to slide the trackpad and fingerprint reader cables out of their connectors on the motherboard.
  44. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 44, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 44, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the three 4 mm screws from the I/O bracket.
  45. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 45, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 45, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 45, 3 resimden 3.
    • Use your fingers to slide the I/O bracket to the left.
    • Lift the I/O bracket up and away from the laptop.
  46. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 46, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 46, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the six 4 mm screws from the motherboard.
    • This laptop does not have an NFC cable, but if yours does, use the flat end of a spudger to flip up the tab and slide the cable out of its connector.
  47. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 47, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 47, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 47, 3 resimden 3.
    • Use both hands to lift the motherboard up and away from the laptop.
  48. Lenovo ThinkPad T470 WLAN Antennas Replacement, Display Assembly: adım 48, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, Display Assembly: adım 48, 2 resimden 2.
    • Use your fingers to remove the camera cable from its slot.
  49. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 49, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 49, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 49, 3 resimden 3.
    • Use your fingers to lift the black and blue wires out of their slots along the top of the laptop.
  50. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 50, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 50, 2 resimden 2.
    • Use your fingers to lift the red and gray wires out of their slots.
  51. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 51, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 51, 2 resimden 2.
    • Use your fingers to lift the LCD cable out of its slot.
  52. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 52, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 52, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove three 4.5 mm screws from the hinge in the upper right corner.
  53. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 53, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 53, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove two 4.5 mm screws from the hinge in the upper left corner.
  54. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 54, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 54, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 54, 3 resimden 3.
    • Use both hands to lift the laptop body up and away from the display assembly.
  55. Lenovo ThinkPad T470 WLAN Antennas Replacement, Display Bezel: adım 55, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, Display Bezel: adım 55, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement, Display Bezel: adım 55, 3 resimden 3.
    • Use the iFixit opening tool to create a gap between the bezel and the display, starting in the upper left corner.
    • Continue to use the iFixit opening tool around the left side, bottom, and right side of the laptop to detach the clips securing the bezel to the display.
    • You may hear loud snaps when detaching the clips; this is normal.
  56. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 56, 1 resimden 1.
    • Insert the iFixit opening tool between the bezel and display on the top side.
    • This part of the bezel is attached to the display with adhesive, so you may need to use your hands to gently peel the bezel away.
  57. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 57, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 57, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 57, 3 resimden 3.
    • Use both hands to lift the bezel up and away from the display assembly.
  58. Lenovo ThinkPad T470 WLAN Antennas Replacement, Display Panel: adım 58, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, Display Panel: adım 58, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the four 3 mm screws from each corner of the screen.
  59. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 59, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 59, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 59, 3 resimden 3.
    • Use both hands to lift the bottom corners of the display panel
    • Gently flip the display panel over.
    • Potential for device damage: The display cable is still connecting the display panel to the rest of the display assembly, so be sure to flip the display panel over with caution.
  60. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 60, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 60, 2 resimden 2.
    Satın Al
    • Use a pair of blunt nose tweezers to remove the clear tape from the display cable.
  61. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 61, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 61, 2 resimden 2.
    • Use the flat end of a spudger to flip up the metal bar securing the connector.
    • Use the flat end of a spudger to disconnect the display cable from its socket.
  62. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 62, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 62, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 62, 3 resimden 3.
    • Use your hands to remove the display panel from the rest of the display assembly.
  63. Lenovo ThinkPad T470 WLAN Antennas Replacement, Hinges: adım 63, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, Hinges: adım 63, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws from the hinge in the upper left corner.
  64. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 64, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 64, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 64, 3 resimden 3.
    • Use your fingers to lift the hinge up and away from the laptop.
  65. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 65, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 65, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 65, 3 resimden 3.
    Satın Al
    • Use a pair of blunt nose tweezers to peel the copper tape off of the hinge frame.
  66. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 66, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 66, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 66, 3 resimden 3.
    • Use your hand to lift the hinge frame up and away from the laptop.
  67. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 67, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 67, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws from the hinge in the upper right corner.
  68. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 68, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 68, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 68, 3 resimden 3.
  69. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 69, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 69, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 69, 3 resimden 3.
  70. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 70, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 70, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 70, 3 resimden 3.
  71. Lenovo ThinkPad T470 WLAN Antennas Replacement, WWAN Antennas: adım 71, 2 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, WWAN Antennas: adım 71, 2 resimden 2.
    Satın Al
    • Use a pair of blunt nose tweezers to peel the copper tape up from the display assembly in the bottom left-hand corner.
  72. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 72, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 72, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 72, 3 resimden 3.
    • Use a spudger to pry the WWAN antenna away from the rest of the display assembly.
    • Use one hand to hold the WWAN antenna.
    • Use your other hand to remove the red wire from its slots along the left side of the display assembly.
  73. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 73, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 73, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 73, 3 resimden 3.
    • Use a pair of blunt nose tweezers to peel the copper tape up from the display assembly in the bottom right-hand corner.
  74. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 74, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 74, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 74, 3 resimden 3.
    • Use your other hand to remove the blue wire from its slots along the right side of the display assembly.
  75. Lenovo ThinkPad T470 WLAN Antennas Replacement, WLAN Antennas: adım 75, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement, WLAN Antennas: adım 75, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement, WLAN Antennas: adım 75, 3 resimden 3.
    • Use a spudger to pry the WLAN antenna away from the display assembly in the bottom left-hand corner.
    • Use one hand to hold the WLAN antenna board.
    • Use your other hand to remove the gray wire from its slots along the left side of the laptop.
  76. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 76, 3 resimden 1. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 76, 3 resimden 2. Lenovo ThinkPad T470 WLAN Antennas Replacement: adım 76, 3 resimden 3.
    • Use a spudger to pry the WLAN antenna away from the display assembly in the bottom right-hand corner.
    • Use your other hand to remove the black wire from its slots along the right side of the laptop.
Sonuç
Kristen Gismondi
85.257 İtibar
215 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.086 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 41
Her zaman: 1,113
