Ana içeriğe geç
Lenovo ThinkPad T470S Keyboard Replacement
Noah Stuart
Noah Stuart ve 2 diğer katkıda bulunanlar
En son November 29, 2023 tarihinde güncellendi
30 dakika
Orta
The keyboard in the Lenovo ThinkPad T470S may need to be replaced if the keys are sticking or not responding. The removal of the keyboard from the device is necessary for replacing the keyboard as well as individual keys. Once the keyboard is removed, popping out individual keys can be accomplished using a spudger. Cleaning the keyboard may also be easier if you remove it from your laptop. This will allow you to ensure a more thorough cleaning of your device.
Neye ihtiyacın var
Parçalar
Aletler
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
Daha fazlasını göster…
  1. Lenovo ThinkPad T470S Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Loosen the screw on the backside of the laptop that holds the keyboard in using a Phillips #000 screwdriver.
  2. Lenovo ThinkPad T470S Keyboard Replacement: adım 2, 1 resimden 1.
    • Open the laptop.
    • Use a spudger to slide the keyboard cover towards the screen.
  3. Lenovo ThinkPad T470S Keyboard Replacement: adım 3, 1 resimden 1.
    • Unscrew the six exposed screws with the Phillips #000 screwdriver.
    • Use the spudger to pop the keyboard out.
  4. Lenovo ThinkPad T470S Keyboard Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T470S Keyboard Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T470S Keyboard Replacement: adım 4, 3 resimden 3.
    • Flip over the top of the keyboard by the display.
    • Potential for device damage: Use caution when flipping the keyboard over; it is still attached to the rest of the laptop with ribbon cables.
    • Open the retaining flaps on the ribbon cable connectors.
    • Slide the ribbon cables out of their connectors.
    • Remove the keyboard from the device.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 214
Her zaman: 8,683
