Ana içeriğe geç
Lenovo ThinkPad T480 Back Cover Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480 Back Cover Replacement, External Battery: adım 1, 2 resimden 1. Lenovo ThinkPad T480 Back Cover Replacement, External Battery: adım 1, 2 resimden 2.
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Back Cover Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480 Back Cover Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480 Back Cover Replacement: adım 2, 3 resimden 3.
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: adım 3, 2 resimden 1. Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Back Cover Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T480 Back Cover Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T480 Back Cover Replacement: adım 4, 3 resimden 3.
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
    I found a tough spudger (or even better a plectrum) is best here as the clips, although easy to separate, hold the case firmly leaving a tight gap which a soft spudger may fail to enter.
    Benjamin Kinsey - Yanıt
    Hi Benjamin, thanks for the tip!
    Sarah Westberg -
    You also have to pry the near the battery. I experienced that you can't pry the front side.
    Minko Kelko - Yanıt
    I used a credit card to pry the clips loose, it worked great. Added 2nd RAM stick easily.
    NFR Computers - Yanıt
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Sarah Westberg
29.713 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
2Kılavuz Yorumları
Dont forget the 3 clips in the removable battery area. No one mentioned those and I ended up breaking a clip and cracking the bottom cover of my T480... :(
Neccros - Yanıt
Hey @neccros! Thanks for the feedback. I'm very sorry you cracked your bottom cover. I've updated the guide to incorporate your experience.
Sarah Westberg -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 74
Son 30 gün: 348
Her zaman: 9,704
