Giriş
A fingerprint reader on your laptop is an additional security feature that works by capturing the pattern of your finger, analyzing the information and comparing it to the prints on file and then unlocking your device if the prints match. If the reader is not working properly or needs to be replaced on your Lenovo ThinkPad T480, this guide will help you replace it.
The fingerprint reader is not something that needs to be replaced often but in the case that it has been damaged, due to a scratch on the surface for example, it may need to be replaced.
Prior to beginning the repair, disable the internal battery, shut down the device, and unplug it from the charger.
Neye ihtiyacın var
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
Hello Sarah,
Thanks for this great guide.
I mistakenly broke this ribbon connector on my T480 and wish you will help with any info where to source a good one and how to fit it back. It has prevent my keyboard from working.
Insert the blue plastic opening tool into the space between the lower case and the chassis.
Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
Remove the back case.
I found a tough spudger (or even better a plectrum) is best here as the clips, although easy to separate, hold the case firmly leaving a tight gap which a soft spudger may fail to enter.
Hi Benjamin, thanks for the tip!
You also have to pry the near the battery. I experienced that you can't pry the front side.
I used a credit card to pry the clips loose, it worked great. Added 2nd RAM stick easily.
Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
Lift the battery straight out of its recess and remove it.
DO NOT wedge out the battery - T480 has two screws that hold down a plastic battery tray which easily lifts out after the two frame screws are removed. Wedging out will ruin the battery and could damage the cell and cause a fire.
The guide says to remove those two screws. They are "lifting" with the wedge. Probably more of a way to promote their tools than out of necessity, but idk
Pull the black plastic sheet back to reveal the RAM stick.
Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it .
Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
Using the black nylon spudger, lift the connector lock up.
Disconnect the storage cable from the system board.
Using the Phillips #1 screwdriver, remove three 4.6 mm screws from the I/O bracket.
Use the black nylon spudger to lift up the small locking flap on the power button cable's ZIF connector.
Slide the power button cable out of the ZIF connector.
Using the black nylon spudger, disconnect the LCD cable from the motherboard.
You got camera and display cable mixed up. The small one is for camera and the long one (50 pin) for screen.
Steps 3-8, 11, 13-16, 18-19, 21-29 can be skipped. Also, there is a step missing for unscrewing screen lid from body.
Using the Phillips #1 screwdriver, remove one screw at the bottom of the bracket covering the fingerprint reader.
2 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Thanks for this detailed guide. I have a question: will you make a guide for T480s? How similar is the process?
Hi @eriknordquist, You're welcome! I'm sorry I didn't create the fingerprint reader replacement guide for the T480s. Unfortunately, I don't have the laptop anymore but I looked at the T480s Hall Sensor guide and it looks like the fingerprint sensor replacement might be a little easier for the T480s than for the T480. The Fingerprint/Smart Card cable is the one next to the hall sensor cable (to the left). It's connected on both ends with ZIF connectors. I think once you disconnect the cable and lift the black plastic shield or tape, the fingerprint reader should be underneath. I'm not sure what the next step is, but I hope that helps you get started.
Thank you, @sarahw, that's encouraging.
