Ana içeriğe geç
Lenovo ThinkPad T480 Internal Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: adım 1, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: adım 1, 2 resimden 2.
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 2, 3 resimden 3.
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: adım 3, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Internal Battery Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 4, 3 resimden 3.
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: adım 5, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 Internal Battery Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 6, 3 resimden 3.
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Internal Battery Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 7, 2 resimden 2.
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Sarah Westberg
29.803 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.670 adet Kılavuz yazıldı
7Kılavuz Yorumları
"What you need" contains a wrong part.
cumledomla - Yanıt
Hi @cumledomla, I've added the internal battery for this guide. Thanks for pointing that out! The external battery will show up in the "What you need" section because it's imported from the prerequisite guide for the external battery. Hope this helps.
Sarah Westberg - Yanıt
The "Battery 2" on my T480 does not load. Is Battery 2 the internal or the external battery?
Finn Hove - Yanıt
Battery1 is the internal
pride tafirei -
Battery 2 is the external battery.
Peter Falk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 38
Son 7 gün: 277
Son 30 gün: 1,406
Her zaman: 47,725
