Ana içeriğe geç
Lenovo ThinkPad T480 Internal Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: adım 1, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: adım 1, 2 resimden 2.
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 2, 3 resimden 3.
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: adım 3, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Internal Battery Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 4, 3 resimden 3.
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
    I found a tough spudger (or even better a plectrum) is best here as the clips, although easy to separate, hold the case firmly leaving a tight gap which a soft spudger may fail to enter.
    Benjamin Kinsey - Yanıt
    Hi Benjamin, thanks for the tip!
    Sarah Westberg -
    You also have to pry the near the battery. I experienced that you can't pry the front side.
    Minko Kelko - Yanıt
    I used a credit card to pry the clips loose, it worked great. Added 2nd RAM stick easily.
    NFR Computers - Yanıt
  5. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: adım 5, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 Internal Battery Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480 Internal Battery Replacement: adım 6, 3 resimden 3.
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Internal Battery Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480 Internal Battery Replacement: adım 7, 2 resimden 2.
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
    DO NOT wedge out the battery - T480 has two screws that hold down a plastic battery tray which easily lifts out after the two frame screws are removed. Wedging out will ruin the battery and could damage the cell and cause a fire.
    Poseidon219 - Yanıt
    The guide says to remove those two screws. They are "lifting" with the wedge. Probably more of a way to promote their tools than out of necessity, but idk
    Lorenzo Serrano - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Sarah Westberg
29.438 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.526 adet Kılavuz yazıldı
7 Yorum
"What you need" contains a wrong part.
cumledomla - Yanıt
Hi @cumledomla, I've added the internal battery for this guide. Thanks for pointing that out! The external battery will show up in the "What you need" section because it's imported from the prerequisite guide for the external battery. Hope this helps.
Sarah Westberg - Yanıt
The "Battery 2" on my T480 does not load. Is Battery 2 the internal or the external battery?
Finn Hove - Yanıt
Battery1 is the internal
pride tafirei -
Battery 2 is the external battery.
Peter Falk - Yanıt
Does anyone know more details about the the two 4.6 mm screws securing the internal battery to the frame?
I have a refurbished t480 with no internal battery, so to install one I will need to also get hold of suitable screws.
I'm assuming 4.6 mm is the length, how about pitch or gauge? Or are they M# something or another style where all that is standardised?
Or any idea where I could look for a part number?
Dru - Yanıt
Hi Dru, you are correct that 4.6 mm is referring to the length of the screws. I looked up the hardware maintenance manual and it shows the screws are M2 x 3 mm, small head, nylon coated. When I measured the screws, the length was different, but you may want to go with the length in the hardware maintenance manual or try both lengths to see which fits best. However, both screw lengths are M2. The manual also lists the Torque as 0.181 Nm (1.85 kgf-cm). I hope this helps! Here is a link to the hardware maintenance manual.
Sarah Westberg -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 42
Son 7 gün: 353
Son 30 gün: 1,359
Her zaman: 47,033
