Ana içeriğe geç
Lenovo ThinkPad T480 SSD Replacement
Dane Elliott-Dyson
Dane Elliott-Dyson ve 3 diğer katkıda bulunanlar
En son September 23, 2024 tarihinde güncellendi
10 - 15 dakika
Orta
Topluluk-Katkılı Kılavuz
This guide will show you how to replace the SSD on your Lenovo Thinkpad T480 laptop. Backup your data before replacing if possible.
  1. Lenovo ThinkPad T480 SSD Replacement, SSD: adım 1, 1 resimden 1.
  2. Lenovo ThinkPad T480 SSD Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 2, 2 resimden 2.
    • Push Clip 1 to the side. While holding Clip 2 to the side, push the battery out of the laptop.
  3. Lenovo ThinkPad T480 SSD Replacement: adım 3, 1 resimden 1.
    • Remove all Phillip-head screws shown.
    • The screws will not come out of the casing, so unscrew them all the way until they don’t go any higher.
  4. Lenovo ThinkPad T480 SSD Replacement: adım 4, 1 resimden 1.
    • Pry up on the casing using a spudger or a flat-head screwdriver and remove the back.
  5. Lenovo ThinkPad T480 SSD Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480 SSD Replacement: adım 5, 3 resimden 3.
    • Pry up on the little metal bar on the connector and pull the connector out of its socket.
  6. Lenovo ThinkPad T480 SSD Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480 SSD Replacement: adım 6, 3 resimden 3.
    • Pry up on the left side of the SSD casing. Pull the casing to the left, and remove.
  7. Lenovo ThinkPad T480 SSD Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 7, 2 resimden 2.
    • Remove the following 4mm Phillip-head screws and remove the plate.
  8. Lenovo ThinkPad T480 SSD Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480 SSD Replacement: adım 8, 3 resimden 3.
    • Remove the 4mm Phillip-head screw and pull the SSD out of its socket.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Dane Elliott-Dyson
618 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 110
Son 30 gün: 539
Her zaman: 5,859
