Ana içeriğe geç
Lenovo ThinkPad T480s USB Card Replacement
Sarah Westberg
Sarah Westberg ve başka bir katkıda bulunan
En son April 23, 2024 tarihinde güncellendi
30 dakika - 1 saat
Orta
Use this guide to replace the USB card in a Lenovo ThinkPad T480s laptop.
The USB Card is used for extra storage and data backup and transfer. If your laptop does not recognize the USB Card, you might receive an error message and it will fail to load. The USB card may be corrupted. You may need to replace it but first do some troubleshooting.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s USB Card Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s USB Card Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s USB Card Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s USB Card Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s USB Card Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: adım 4, 2 resimden 1. Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: adım 4, 2 resimden 2.
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s USB Card Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad T480s USB Card Replacement: adım 5, 2 resimden 2.
    • Loosen the six captive screws attaching the fan assembly to the motherboard.
    • This system was missing the two screws by the fan but I have highlighted them to show where they are located.
  6. Lenovo ThinkPad T480s USB Card Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480s USB Card Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480s USB Card Replacement: adım 6, 3 resimden 3.
    • Lift the thermal fan assembly from the system and remove it.
  7. Lenovo ThinkPad T480s USB Card Replacement, USB Card: adım 7, 3 resimden 1. Lenovo ThinkPad T480s USB Card Replacement, USB Card: adım 7, 3 resimden 2. Lenovo ThinkPad T480s USB Card Replacement, USB Card: adım 7, 3 resimden 3.
    • Use a spudger to disconnect the cable from the USB card.
  8. Lenovo ThinkPad T480s USB Card Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T480s USB Card Replacement: adım 8, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove two 3 mm screws from the USB card.
  9. Lenovo ThinkPad T480s USB Card Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T480s USB Card Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T480s USB Card Replacement: adım 9, 3 resimden 3.
    • With your fingers, lift the USB card from the system.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Sarah Westberg
29.489 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.537 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 874
