Ana içeriğe geç
Lenovo ThinkPad T580 Cooling Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T580 Cooling Fan Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T580 Cooling Fan Replacement, External Battery: adım 1, 3 resimden 3.
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Cooling Fan Replacement, Bottom Case: adım 4, 2 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement, Bottom Case: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 6, 3 resimden 3.
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Cooling Fan Replacement, Cooling Fan: adım 7, 2 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement, Cooling Fan: adım 7, 2 resimden 2.
    • Unplug the cooling fan's cable from the the motherboard.
  8. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Using a Phillips #00 screwdriver, unscrew five 4.6 mm screws fastening the fan and cooling pipe.
    • The screws are set in the plastic and are not able to be removed from the fan parts.
  9. Lenovo ThinkPad T580 Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Remove the cooling fan directly upwards from the core.
    • Be sure to clean and replace any thermal paste on the heatsink and CPU before reassembling. You can use our How to Apply Thermal Paste guide if you need any help!
Sonuç
Ben Elkayam
954 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G6, White Winter 2020 Cal Poly, Team S18-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S18G6
4 Üyeler
24 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 2,328
