Ana içeriğe geç
Lenovo ThinkPad T580 Trackpad Replacement
Ben Elkayam
Ben Elkayam ve 6 diğer katkıda bulunanlar
En son May 30, 2024 tarihinde güncellendi
10 - 30 dakika
Orta
Welcome to the trackpad replacement guide for the Lenovo Thinkpad T580.
This guide will detail the steps necessary to replace the trackpad.
The most common reasons why this component would need to be replaced is because:
  • The mouse skips around often
  • The trackpad does not function
  • The trackpad is visibly damaged
If you are not experiencing these problems with this component consider examining the troubleshooting page for this device.
There are no specialized skills required for replacing the trackpad.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Lenovo ThinkPad T580 Trackpad Replacement, External Battery: adım 1, 3 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement, External Battery: adım 1, 3 resimden 2. Lenovo ThinkPad T580 Trackpad Replacement, External Battery: adım 1, 3 resimden 3.
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Trackpad Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T580 Trackpad Replacement: adım 2, 3 resimden 3.
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Trackpad Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T580 Trackpad Replacement: adım 3, 3 resimden 3.
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: adım 4, 2 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: adım 4, 2 resimden 2.
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Trackpad Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T580 Trackpad Replacement: adım 5, 3 resimden 3.
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Trackpad Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T580 Trackpad Replacement: adım 6, 3 resimden 3.
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Trackpad Replacement, Internal Battery: adım 7, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Trackpad Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T580 Trackpad Replacement: adım 8, 3 resimden 3.
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: adım 9, 2 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
  10. Lenovo ThinkPad T580 Trackpad Replacement: adım 10, 2 resimden 1. Lenovo ThinkPad T580 Trackpad Replacement: adım 10, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove four 2.2 mm screws holding the trackpad.
    • Pull the trackpad out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ben Elkayam
1.039 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G6, White Winter 2020 Cal Poly, Team S18-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S18G6
4 Üyeler
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 39
Son 30 gün: 104
Her zaman: 4,540
