Ana içeriğe geç
Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement
Clay Eickemeyer
Clay Eickemeyer ve başka bir katkıda bulunan
En son March 20, 2024 tarihinde güncellendi
10 - 20 dakika
Kolay
This guide will walk you through the process of removing the battery from your Lenovo ThinkPad X1 Carbon. This is an important step before performing any repairs or replacements in your laptop.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the back cover: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to loosen the five captive screws holding the back cover.
  2. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the corner clips: adım 2, 2 resimden 2.
    • Insert an opening pick between a corner of the back cover and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when clips release.
    • Repeat this process for the opposite corner.
  3. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: adım 3, 2 resimden 1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Release the edge clips: adım 3, 2 resimden 2.
    • Insert the opening pick between the cover and the body.
    • Pry upward and release all of the retaining clips.
  4. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: adım 4, 2 resimden 1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the back cover: adım 4, 2 resimden 2.
    • Lift the back cover off the chassis and remove it.
    • If the cover feels stuck to the chassis, use an opening pick to release any remaining clips around the perimeter of the back cover.
  5. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: adım 5, 2 resimden 1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Unfasten the battery: adım 5, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the six 4.9 mm screws securing the battery to the laptop chassis.
  6. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: adım 6, 3 resimden 1. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: adım 6, 3 resimden 2. Lenovo ThinkPad X1 Carbon 9th Gen Battery Replacement, Remove the battery: adım 6, 3 resimden 3.
    • Grip the corners of the battery.
    • Pull and lift the battery of its recess and remove it.
    • Be delicate when pulling the battery out at first. The small pins on its connector are easy to bend.
    • There is no cable for the battery. It disconnects when removed from its recess.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad X1 Carbon community for help.
3 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
81.815 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.419 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 75
Son 30 gün: 385
Her zaman: 8,911
