Ana içeriğe geç
Lenovo ThinkPad X1 Extreme SSD Replacement
Addy Botao Liu
Addy Botao Liu ve 5 diğer katkıda bulunanlar
En son January 17, 2025 tarihinde güncellendi
15 - 25 dakika
Kolay
Daha İyi Resimler Gerekli
This guide will lead you through the steps to replace the SSD card on the Lenovo ThinkPad X1 Extreme Generation 1. The SSD card, or solid-state drive, acts as extra storage for the device, however, oftentimes the SSD can wear out, or run slower with age.
The steps to replace the SSD card are simple, the hardest part being keeping track of all the screws while taking apart the device.
It is important to remember to turn off the device while replacing the SSD card.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: adım 2, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X1 Extreme SSD Replacement: adım 3, 2 resimden 2.
    • Using the opening tool, pop out the SSD card and remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 41
Her zaman: 2,318
