Ana içeriğe geç
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: adım 2, 1 resimden 1.
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: adım 3, 1 resimden 1.
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: adım 4, 3 resimden 1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: adım 4, 3 resimden 2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: adım 5, 1 resimden 1.
    • Lift the battery out of the frame and remove it from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Beckham Richmond
467 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G3
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - Yanıt
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 67
Son 30 gün: 243
Her zaman: 12,166
