Ana içeriğe geç
Lenovo ThinkPad X1 Yoga Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Yoga Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Battery Replacement, Speakers: adım 2, 1 resimden 1.
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Battery Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Battery Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad X1 Yoga Battery Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad X1 Yoga Battery Replacement: adım 4, 3 resimden 3.
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: adım 5, 3 resimden 1. Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: adım 5, 3 resimden 2. Lenovo ThinkPad X1 Yoga Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Battery Replacement: adım 6, 1 resimden 1.
    • Lift and remove the battery away from the computer.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Hello, I was able to install the battery on my X1 carbon, but the laptop is not detecting my battery. How to remove whitelisting on X1 carbon yoga 1st gen?
Delta Force - Yanıt
Did you find a solution for your problem? Because i have the same problem since i changed my battery :/
Sarah -
Very useful instructions. I was able to replace the battery without any problems. Thank you very much.
Carlos Oppenheimer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 176
Son 30 gün: 862
Her zaman: 34,693
