Ana içeriğe geç
Lenovo ThinkPad X280 CMOS Battery Replacement
Hannah Bryn Cullen
Hannah Bryn Cullen ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
50 dakika
Orta
This will take approximately 50 minutes to complete from beginning to end.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo ThinkPad X280 CMOS Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 CMOS Battery Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X280 CMOS Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 CMOS Battery Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X280 CMOS Battery Replacement: adım 3, 2 resimden 2.
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: adım 4, 3 resimden 1. Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: adım 4, 3 resimden 2. Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 CMOS Battery Replacement, CMOS Battery: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to gently unplug the CMOS Battery from the port on the right side.
  6. Lenovo ThinkPad X280 CMOS Battery Replacement: adım 6, 1 resimden 1.
    • Work the wire out from its holding brackets and is now free to be removed.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 48
Son 30 gün: 195
Her zaman: 4,181
