Ana içeriğe geç
Lenovo ThinkPad X280 Power Jack Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X280 Power Jack Replacement, Back Panel: adım 1, 1 resimden 1.
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Power Jack Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Power Jack Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement: adım 3, 2 resimden 2.
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Power Jack Replacement, Battery: adım 4, 3 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement, Battery: adım 4, 3 resimden 2. Lenovo ThinkPad X280 Power Jack Replacement, Battery: adım 4, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Power Jack Replacement, Power Jack: adım 5, 2 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement, Power Jack: adım 5, 2 resimden 2.
    • Disconnect all six ribbon cables connected to the motherboard by gently with a screwdriver or your fingers.
    • Flip up the locking flaps before disconnecting the cables where pertinent.
  6. Lenovo ThinkPad X280 Power Jack Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement: adım 6, 2 resimden 2.
    • Remove the two 5.4 mm screws securing the metal bracket with a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X280 Power Jack Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement: adım 7, 2 resimden 2.
    • Remove the two 5.4 mm screws securing the plastic bracket with a Phillips #1 screwdriver.
  8. Lenovo ThinkPad X280 Power Jack Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement: adım 8, 2 resimden 2.
    • Remove all fifteen 3.4 mm screws securing the motherboard with a Phillips #1 screwdriver.
  9. Lenovo ThinkPad X280 Power Jack Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad X280 Power Jack Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad X280 Power Jack Replacement: adım 9, 3 resimden 3.
    • Lift out the mother board to access the power jack to replace it with a new one.
    • The power jack will have to be desoldered and then the replacement resoldered. Check out this handy guide to help guide you.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 37
Her zaman: 104
