Ana içeriğe geç
Lenovo ThinkPad X280 Speaker Replacement
Jordan Wooten
Jordan Wooten ve 4 diğer katkıda bulunanlar
En son December 27, 2021 tarihinde güncellendi
25 - 30 dakika
Orta
This replacement guide will inform users on how to remove the speakers on the Lenovo ThinkPad X280.
The speakers are used to project sound from the device by converting electrical signals to vibrations that create sound waves.
It is important to note that speakers can come in various sizes and shapes and produce various levels of sound depending on your device’s adjusted volume level. Make sure your device’s volume is at a sufficient amount when testing the audio.
If there is no audio produced from your device, static noise from cooling fans, and/or a corrupted sound driver, your speaker can fail to play audio or clear sound.
For an additional guide to troubleshooting your audio issues, you can review this troubleshooting guide and/or this document.
Neye ihtiyacın var
Aletler
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X280 Speaker Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X280 Speaker Replacement: adım 3, 2 resimden 2.
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: adım 4, 3 resimden 1. Lenovo ThinkPad X280 Speaker Replacement, Battery: adım 4, 3 resimden 2. Lenovo ThinkPad X280 Speaker Replacement, Battery: adım 4, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: adım 5, 3 resimden 1. Lenovo ThinkPad X280 Speaker Replacement, Speakers: adım 5, 3 resimden 2. Lenovo ThinkPad X280 Speaker Replacement, Speakers: adım 5, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X280 Speaker Replacement: adım 6, 2 resimden 2.
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove speakers and wiring from device.
Sonuç
Jordan Wooten
615 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 1,768
