Ana içeriğe geç
Lenovo Thinkpad T450 SSD Replacement
Justin Ogihara
Justin Ogihara ve başka bir katkıda bulunan
En son September 11, 2023 tarihinde güncellendi
10 - 25 dakika
Orta
The solid-state drive (or SSD) is a storage device used to store data. SSDs are much faster than the traditional hard-disc drives (HDD) due to their physical nature. Unlike the standard HDD, an SSD does not have a physical spinning disc in the component. Current estimates show that SSDs may reach a lifespan of 10 years, but the average lifespan of a SSD is shorter.
If your Lenovo ThinkPad T450 laptop is not properly loading files or is slow to load, it may be time to replace the SSD. Follow these instructions to replace the SSD in your device.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo Thinkpad T450 SSD Replacement, External Battery: adım 1, 3 resimden 1. Lenovo Thinkpad T450 SSD Replacement, External Battery: adım 1, 3 resimden 2. Lenovo Thinkpad T450 SSD Replacement, External Battery: adım 1, 3 resimden 3.
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 SSD Replacement, Back Cover: adım 2, 1 resimden 1.
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 SSD Replacement: adım 3, 3 resimden 1. Lenovo Thinkpad T450 SSD Replacement: adım 3, 3 resimden 2. Lenovo Thinkpad T450 SSD Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 SSD Replacement, SSD: adım 4, 1 resimden 1.
    • Using the JIS #00 screwdriver, remove the single 2.8 mm screw securing the SSD to the device.
  5. Lenovo Thinkpad T450 SSD Replacement: adım 5, 2 resimden 1. Lenovo Thinkpad T450 SSD Replacement: adım 5, 2 resimden 2.
    • Lift the SSD up and to the left and remove it from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justin Ogihara
29.133 İtibar
52 adet Kılavuz yazıldı
Ekip
EDU Team EDU Team üyesi
Staff
7 Üyeler
756 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 35
Son 30 gün: 170
Her zaman: 5,777
