Ana içeriğe geç
Lenovo V14-IIL Camera Replacement
Sydney Askins
Sydney Askins ve 2 diğer katkıda bulunanlar
En son June 18, 2024 tarihinde güncellendi
1 saat
Orta
Öğrenci İş Başında
Impact damage, closing the laptop with excessive force, and scratches on the camera lens can cause the camera to break or develop bad image quality. This guide shows how to replace the camera within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Lenovo V14-IIL Camera Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo V14-IIL Camera Replacement, Back Panel: adım 1, 2 resimden 2.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Camera Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Camera Replacement: adım 3, 1 resimden 1.
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Camera Replacement, Display Assembly: adım 4, 2 resimden 1. Lenovo V14-IIL Camera Replacement, Display Assembly: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
  5. Lenovo V14-IIL Camera Replacement: adım 5, 1 resimden 1.
    • Lift up the latch and gently pull the display cable free.
  6. Lenovo V14-IIL Camera Replacement: adım 6, 2 resimden 1. Lenovo V14-IIL Camera Replacement: adım 6, 2 resimden 2.
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  7. Lenovo V14-IIL Camera Replacement: adım 7, 1 resimden 1.
    • Ensure that all cables and hinges are detached.
    • Lift the display assembly away from the base.
  8. Lenovo V14-IIL Camera Replacement, Screen Bezel: adım 8, 2 resimden 1. Lenovo V14-IIL Camera Replacement, Screen Bezel: adım 8, 2 resimden 2.
    • Slide the cable hinge cover to the right.
    • Pull the part away from the screen.
  9. Lenovo V14-IIL Camera Replacement: adım 9, 2 resimden 1. Lenovo V14-IIL Camera Replacement: adım 9, 2 resimden 2.
    • Use the iFixit opening tool to separate the bezel panel.
    • Slide the opening tool all the way around to loosen the bezels on all sides.
    • You may need to use the tool to gently loosen the adhesive tape.
    • Lift away the bezel panel.
  10. Lenovo V14-IIL Camera Replacement, Camera: adım 10, 1 resimden 1.
    • Gently pull out the stretch adhesive tape.
    • Make sure to pull from hinges to the top of the LCD panel.
    • You may need to use the metal spudger to help loosen the adhesive.
  11. Lenovo V14-IIL Camera Replacement: adım 11, 1 resimden 1.
    • Disconnect the wire from the back of the integrated camera and lift the camera away.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sydney Askins
378 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 95
