Ana içeriğe geç
Lenovo V14-IIL Fan Replacement
K.Radford
K.Radford ve 2 diğer katkıda bulunanlar
En son June 18, 2024 tarihinde güncellendi
45 dakika
Orta
Öğrenci İş Başında
Öne Çıkan Öğrenci Kılavuzu
Fan damage or normal wear may cause the computer to overheat during use. This guide shows how to replace the fan within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Lenovo V14-IIL Fan Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo V14-IIL Fan Replacement, Back Panel: adım 1, 2 resimden 2.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Fan Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Fan Replacement: adım 3, 1 resimden 1.
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Fan Replacement, Fan: adım 4, 2 resimden 1. Lenovo V14-IIL Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the three 6 mm screws holding the fan.
  5. Lenovo V14-IIL Fan Replacement: adım 5, 3 resimden 1. Lenovo V14-IIL Fan Replacement: adım 5, 3 resimden 2. Lenovo V14-IIL Fan Replacement: adım 5, 3 resimden 3.
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  6. Lenovo V14-IIL Fan Replacement: adım 6, 1 resimden 1.
    • Lift out the fan gently pulling until the four cables disconnect from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
K.Radford
324 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 147
