Ana içeriğe geç
Lenovo YOGA 730-15IKB Speaker Replacement
Ellis Ruckman
Ellis Ruckman ve 2 diğer katkıda bulunanlar
En son July 7, 2021 tarihinde güncellendi
10 - 20 dakika
Kolay
Follow this guide to replace the speakers in your Lenovo YOGA 730-15IKB.
Before replacing your speakers, make sure that you have ruled out any software audio issues. For example, make sure the volume is not muted and that the audio driver is installed.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo YOGA 730-15IKB Speaker Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Speaker Replacement: adım 2, 2 resimden 1. Lenovo YOGA 730-15IKB Speaker Replacement: adım 2, 2 resimden 2.
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Speaker Replacement: adım 3, 1 resimden 1.
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: adım 4, 3 resimden 1. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: adım 4, 3 resimden 2. Lenovo YOGA 730-15IKB Speaker Replacement, Speaker: adım 4, 3 resimden 3.
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Speaker Replacement: adım 5, 2 resimden 1. Lenovo YOGA 730-15IKB Speaker Replacement: adım 5, 2 resimden 2.
    • When the laptop is upside down, the left speaker is located on the right side of the computer.
    • Pull up on the left speaker to remove it from the chassis.
    • Do not fully remove the left speaker at this point. Notice that the left and right speakers are still connected by a wire.
  6. Lenovo YOGA 730-15IKB Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the red and black wire near the front of the laptop from underneath the hooks that hold it in place.
  7. Lenovo YOGA 730-15IKB Speaker Replacement: adım 7, 2 resimden 1. Lenovo YOGA 730-15IKB Speaker Replacement: adım 7, 2 resimden 2.
Sonuç
Ellis Ruckman
2.647 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S1G6
3 Üyeler
27 adet Kılavuz yazıldı
Bir Yorum
when the stock can arrive ?
prashantdushara - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 1,007
