Giriş
This guide will show you how to replace the battery in a Lenovo Yoga 710-15ISK laptop. The battery of your laptop is an essential component that allows it to power on and stay on without being plugged in. Before replacing your battery, ensure the charge of the battery is drained. Signs your battery needs to be replaced are reduced battery life, the computer won’t turn on when not plugged in, and the battery is overheating.
Neye ihtiyacın var
Flip your laptop over so the bottom is facing upwards.
Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
