Ana içeriğe geç
Lenovo Yoga 720 Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 720 Battery Replacement, Bottom Cover: adım 1, 3 resimden 1. Lenovo Yoga 720 Battery Replacement, Bottom Cover: adım 1, 3 resimden 2. Lenovo Yoga 720 Battery Replacement, Bottom Cover: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    T5 Torx Screwdriver
    $5.49
    Satın Al
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 Battery Replacement: adım 2, 3 resimden 1. Lenovo Yoga 720 Battery Replacement: adım 2, 3 resimden 2. Lenovo Yoga 720 Battery Replacement: adım 2, 3 resimden 3.
    iFixit Opening Tool
    $1.99
    Satın Al
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 Battery Replacement: adım 3, 3 resimden 1. Lenovo Yoga 720 Battery Replacement: adım 3, 3 resimden 2. Lenovo Yoga 720 Battery Replacement: adım 3, 3 resimden 3.
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  4. Lenovo Yoga 720 Battery Replacement, Battery: adım 4, 3 resimden 1. Lenovo Yoga 720 Battery Replacement, Battery: adım 4, 3 resimden 2. Lenovo Yoga 720 Battery Replacement, Battery: adım 4, 3 resimden 3.
    JIS Driver Set
    $19.99
    Satın Al
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove four J1 Philips screws.
    • Remove one J1 philips screw.
    • Do not mix these screws up. If you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • Lift the battery slightly using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  5. Lenovo Yoga 720 Battery Replacement: adım 5, 3 resimden 1. Lenovo Yoga 720 Battery Replacement: adım 5, 3 resimden 2. Lenovo Yoga 720 Battery Replacement: adım 5, 3 resimden 3.
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
18 farklı kişi bu kılavuzu tamamladı.
Aiden
17.486 İtibar
21 adet Kılavuz yazıldı
6 Yorum
Hi Aiden. I have the Lenovo yoga 720-12ikb. Is a bit smaller. Do you know if the same instructions will work on this unit? Thanks
ignagonza1973 - Yanıt
I just would like to let people know that when reassembling you need to push the connector firmly all the way otherwise battery will not be properly connected. Make sure to note the position of the switch when unplugging.
François Devoret - Yanıt
This worked great, my yoga should keep on chugging for years to cone.
Robert Proaps - Yanıt
On my Yoga 720-131KB, there were only four J1 Philips screws securing the battery in Step 4. There was no longer screw marked in yellow, nor was there a screw attachment point on the battery.
Thank you for preparing this guide!
Stephen Ching - Yanıt
Great instructions, as usual. This was my second battery replacement (two separate computers: 720 and 730). They look similar, but screws are placed differently, and case comes apart in the opposite direction. Battery is the same though. Since they were 3 and 4 years old, the batteries were totally shot, and computers would shut down suddenly, even when apparently at 100% charge. I'm hoping this replacement will keep them going a few more years.
That battery connection is really small, it's hard to get much leverage to reconnect the new battery. Still, as others have said, pay attention to the orientation of the connector, make sure it's aligned, and be patient. If you line it up just right, it'll glide in. Make sure it goes in all the way.
frank g - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 49
Son 30 gün: 241
Her zaman: 24,952
