Ana içeriğe geç
Logitech G X56 HOTAS Throttle Switch Board Replacement
Neye ihtiyacın var
  1. Logitech G X56 HOTAS Throttle Switch Board Replacement, Label Plate: adım 1, 2 resimden 1. Logitech G X56 HOTAS Throttle Switch Board Replacement, Label Plate: adım 1, 2 resimden 2.
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
    FixBot'a Sor
  2. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry off the mode switch knob.
    FixBot'a Sor
  3. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 3, 3 resimden 1. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 3, 3 resimden 2. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 3, 3 resimden 3.
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
    FixBot'a Sor
  4. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 4, 2 resimden 1. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 4, 2 resimden 2.
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
    FixBot'a Sor
  5. Logitech G X56 HOTAS Throttle Switch Board Replacement, Switch Board: adım 5, 2 resimden 1. Logitech G X56 HOTAS Throttle Switch Board Replacement, Switch Board: adım 5, 2 resimden 2.
    • Remove the 14 mm nuts at the base of the switches.
    FixBot'a Sor
  6. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 6, 1 resimden 1.
    • Disconnect the connectors and de-solder the one black wire.
    FixBot'a Sor
  7. Logitech G X56 HOTAS Throttle Switch Board Replacement: adım 7, 1 resimden 1.
    • Remove and replace the toggle switch daughterboard.
    FixBot'a Sor
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 256
