Ana içeriğe geç
Logitech G435 Battery Replacement
Neye ihtiyacın var
    1. Logitech G435 Battery Replacement, Prepare the headset for disassembly: adım 1, 1 resimden 1.
      • Power off the headset and unplug all cables.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech G435 Battery Replacement, Remove the ear pads: adım 2, 3 resimden 1. Logitech G435 Battery Replacement, Remove the ear pads: adım 2, 3 resimden 2. Logitech G435 Battery Replacement, Remove the ear pads: adım 2, 3 resimden 3.
      • If you're replacing the headset battery, you only need to remove the left ear pad (the side containing the power button).
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech G435 Battery Replacement, Remove the screw sticker: adım 3, 2 resimden 1. Logitech G435 Battery Replacement, Remove the screw sticker: adım 3, 2 resimden 2.
      • Use angled tweezers to peel up and remove the sticker covering the top-left speaker plate screw.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech G435 Battery Replacement, Remove the speaker plate screws: adım 4, 1 resimden 1.
      • Use a T5 Torx driver to remove the four 6.1 mm‑long screws securing the speaker plate.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech G435 Battery Replacement, Secure the speaker plate: adım 5, 3 resimden 1. Logitech G435 Battery Replacement, Secure the speaker plate: adım 5, 3 resimden 2. Logitech G435 Battery Replacement, Secure the speaker plate: adım 5, 3 resimden 3.
      • Don't try to fully remove the speaker plate—it's still attached by some wires.
      • Use your fingers to swing the speaker plate out of the housing.
      • Use some tape to secure the speaker plate to the headband. This keeps the speaker plate out of the way while preventing the speaker wire from being strained.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech G435 Battery Replacement, Remove the circuit board screws: adım 6, 1 resimden 1.
      • Use a Phillips screwdriver to remove the two 4.6 mm‑long screws securing the circuit board.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech G435 Battery Replacement, Detach the circuit board: adım 7, 3 resimden 1. Logitech G435 Battery Replacement, Detach the circuit board: adım 7, 3 resimden 2. Logitech G435 Battery Replacement, Detach the circuit board: adım 7, 3 resimden 3.
      • The circuit board is still connected by many wires. Be gentle as you move the board to prevent damaging any wires.
      • Use your fingers to lift the circuit board slightly out of its recess.
      • Flip the circuit board over so you can access the underside.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech G435 Battery Replacement, Disconnect the battery: adım 8, 3 resimden 1. Logitech G435 Battery Replacement, Disconnect the battery: adım 8, 3 resimden 2. Logitech G435 Battery Replacement, Disconnect the battery: adım 8, 3 resimden 3.
      • Use tweezers to firmly grip the edges of the battery connector.
      • Gently rock the connector side-to-side and slide it out of its socket.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech G435 Battery Replacement, Remove the battery: adım 9, 3 resimden 1. Logitech G435 Battery Replacement, Remove the battery: adım 9, 3 resimden 2. Logitech G435 Battery Replacement, Remove the battery: adım 9, 3 resimden 3.
      • The battery is lightly adhered to the ear cup.
      • Insert the flat end of a spudger underneath the battery.
      • Pry gently to release the battery from the ear cup.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech G435 Battery Replacement, Transfer the battery pad: adım 10, 2 resimden 1. Logitech G435 Battery Replacement, Transfer the battery pad: adım 10, 2 resimden 2.
      • Use your fingers to peel the foam pad from the battery.
      • Transfer the pad onto the same side of the replacement battery.
      FixBot'a Sor
      Yorum Ekle
    9. Logitech G435 Battery Replacement, Attach the battery: adım 11, 3 resimden 1. Logitech G435 Battery Replacement, Attach the battery: adım 11, 3 resimden 2. Logitech G435 Battery Replacement, Attach the battery: adım 11, 3 resimden 3.
      Bu adımda kullanılan alet:
      Tesa 61395 Tape
      $2.95
      • Cut and attach a small strip of double-sided tape onto the battery.
      • Use your finger to press the battery onto the ear cup such that the wires face towards the circuit board socket.
      FixBot'a Sor
      Yorum Ekle
    10. Logitech G435 Battery Replacement, Reconnect the battery: adım 12, 2 resimden 1. Logitech G435 Battery Replacement, Reconnect the battery: adım 12, 2 resimden 2.
      • Use your fingers to slide the battery connector fully into its circuit board socket.
      FixBot'a Sor
      Yorum Ekle
    11. Logitech G435 Battery Replacement, Install the circuit board: adım 13, 2 resimden 1. Logitech G435 Battery Replacement, Install the circuit board: adım 13, 2 resimden 2.
      • Use your fingers to gently flip the circuit board back over its recess.
      FixBot'a Sor
      Yorum Ekle
    12. Logitech G435 Battery Replacement: adım 14, 3 resimden 1. Logitech G435 Battery Replacement: adım 14, 3 resimden 2. Logitech G435 Battery Replacement: adım 14, 3 resimden 3.
      • Align the circuit board notch on the right side of the USB-C port to the ridge on the ear cup.
      • Insert the circuit board at a downward angle and guide the USB-C port into its cutout.
      • Press the bottom edge of the board against the ear cup and tilt the board down.
      • This is a tight fit, as the board has to clear the screw post next to the port to be properly seated.
      FixBot'a Sor
      Yorum Ekle
    13. Logitech G435 Battery Replacement: adım 15, 1 resimden 1.
      • Use a Phillips screwdriver to install the two 4.6 mm‑long screws to secure the circuit board.
      FixBot'a Sor
      Yorum Ekle
    14. Logitech G435 Battery Replacement, Install the speaker plate: adım 16, 2 resimden 1. Logitech G435 Battery Replacement, Install the speaker plate: adım 16, 2 resimden 2.
      • Use your fingers to swing the speaker plate back into place.
      FixBot'a Sor
      Yorum Ekle
    15. Logitech G435 Battery Replacement: adım 17, 1 resimden 1.
      • Use a T5 Torx driver to install the four 6.1 mm‑long screws to secure the speaker plate.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech G435 Battery Replacement, Install the ear pad: adım 18, 3 resimden 1. Logitech G435 Battery Replacement, Install the ear pad: adım 18, 3 resimden 2. Logitech G435 Battery Replacement, Install the ear pad: adım 18, 3 resimden 3.
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • Orient the ear pad so the wider part is at the top.
      • With your free hand, place the pad over the top of the cup, so the black fabric flap slips over the cup's plastic lip.
      • The ear pad has a clear plastic stiffener. This piece should not slip over the ear cup lip.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech G435 Battery Replacement: adım 19, 2 resimden 1. Logitech G435 Battery Replacement: adım 19, 2 resimden 2.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Congratulations on completing your repair!
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Bir başkası bu kılavuzu tamamladı.
Arthur Shi
344.889 İtibar
915 adet Kılavuz yazıldı
2Kılavuz Yorumları
Sehr gute Beschreibung - In 15min war alles fertig! TOP
BigRob - Yanıt Paylaş
Thank you very much. This was an easy repair thanks to your guide.
Thanks Logitech for doing the right thing as well.
Robert Basantsov - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 109
Son 30 gün: 489
Her zaman: 3,402
