Giriş
Use this guide to replace the battery in a Logitech G903.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
This guide requires removing the mouse feet. If you’re planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
You might need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Before you begin, flip the mouse's power switch into the red OFF position.
Heat an iOpener and apply it to the bottom mouse foot for two minutes.
Slide an opening pick under an edge of the bottom mouse foot.
Slide the pick under the rest of the foot until you can lift it off the mouse.
Remove the foot.
Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
Peel the adhesive off.
Repeat the previous mouse feet removal procedure and remove the two pentagonal mouse feet on the left and right side.
Heat an iOpener and apply it to the Logitech sticker to loosen its adhesive.
Slide an opening pick under an edge of the Logitech sticker.
Slide the pick under the rest of the sticker until you can peel it off the mouse.
Remove the sticker.
You don't need to fully remove this sticker, all you need to do is flip the thinnest part (like till you reach the part like in the photo above), put the screwdriver in, unscrew the screw, take the screw out and stick the sticker back on. Do the same with the other screw and during the assembly.
Use a Phillips screwdriver to remove the seven 4.5 mm screws securing the two halves of the mouse together.
You'll need a T5 bit to remove the seventh top screw.
It used to be that on the older models, but on the newer one I just opened it had a Philips for that last one too, just like the guide shows.
For better access, open the top half of the mouse in the direction of the rear end.
Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable ZIF connector.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of blunt nose tweezers or your fingers to slide the interconnect cable out of its socket.
Use a pair of blunt tweezers to grasp the sides of the battery connector.
Pull the connector up and out of its socket, gently rocking it back and forth to loosen the clips securing it.
Insert an opening pick in to the gap between the battery housing and the battery at the side opposite to the battery cable.
Slide the opening pick under the battery and lift up to pry the battery off of its housing.
Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
11 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
This guide helped me on my G900's battery. Thank you!
G903: Easy peasy. Took longer to clean the glue residues up than to open, replace the battery and close it back up.
