Giriş
Use this guide to replace a worn-out or dead battery in your Logitech G915 TKL wireless keyboard.
Lithium-ion batteries have a limited lifespan. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
If possible, follow this guide after your battery has fallen below 15% charge—this is indicated when the battery light on the top edge of the keyboard is red. While your G915 TKL keyboard has a relatively small battery, any charged battery is a potential safety hazard if accidentally bent or punctured.
If your battery looks puffy or swollen, take extra precautions.
Neye ihtiyacın var
Slide the power switch on the top edge of your keyboard into the OFF position.
Unplug all cables from your keyboard.
Lay your keyboard down with the feet facing up on a clean work surface.
Heat an iOpener and lay it on the Logitech sticker for one minute.
Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
Remove the battery from its cover.
Bu adımda kullanılan alet:Tesa 61395 Tape$5.99
Cut a piece of double-sided tape so it fits on the line of squares on the bottom of the battery cover.
Press the tape firmly into place on the squares and remove the plastic backing.
Insert the new battery's connector into its socket so the side with exposed pins is on the bottom.
Use a spudger to push the battery connector fully into its socket.
Set the battery cover into place and firmly press down around its edges to engage all the clips.
