Giriş
Use this guide to replace a worn-out or dead battery in your Logitech G915 TKL wireless keyboard.
Lithium-ion batteries have a limited lifespan. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
If possible, follow this guide after your battery has fallen below 15% charge—this is indicated when the battery light on the top edge of the keyboard is red. While your G915 TKL keyboard has a relatively small battery, any charged battery is a potential safety hazard if accidentally bent or punctured.
If your battery looks puffy or swollen, take extra precautions.
Neye ihtiyacın var
Slide the power switch on the top edge of the keyboard to the OFF (left) position.
Unplug all cables from the keyboard.
Lay the keyboard down with the feet facing up on a clean work surface.
Heat an iOpener and lay it on the Logitech sticker for one minute.
Use a Phillips screwdriver to remove the two 4 mm‑long screws securing the battery cover.
If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
Insert your finger into the USB receiver compartment on the battery cover.
Pull up the bottom edge of the cover to release the clips.
Gently pull the cover to the right so you can access the battery connector on the left side of the recess.
Use a pair of angled tweezers to firmly grip the battery connector.
Slide the connector straight out of its socket.
Gently slide the flat end of a spudger under one of the short edges of the battery and lift to separate the adhesive.
Remove the battery from its cover.
Bu adımda kullanılan alet:Tesa 61395 Tape$5.99
Cut a piece of double-sided tape so it fits on the line of squares on the inside of the battery cover.
Press the tape firmly into place on the squares and remove the liner.
Insert the new battery's connector into its socket so the side with exposed pins is on the bottom.
Use a spudger to push the battery connector fully into its socket.
Set the battery cover into place and firmly press down around its edges to engage all the clips.
Use a Phillips screwdriver to install the two 4 mm‑long screws securing the battery cover.
Use your fingers to apply the sticker to the battery cover.
Bir başkası bu kılavuzu tamamladı.
