Giriş
Follow this guide to remove and replace the battery on a Logitech G935 headset. You may need to do this repair if the battery no longer holds a charge.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Use the indent on the right ear cup door to lift and detach the magnets from the headset.
Pull on the tab at the top of the battery to dislodge it from the recess.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech G935 Answers community for help.
9 farklı kişi bu kılavuzu tamamladı.
