Giriş
If your Logitech M125 cord has stopped retracting or no longer transmits data, use this guide to help replace the cord.
The power cord provides connectivity and mouse movement.
If you are having issues getting the mouse to connect properly, or the cord will not retract anymore, consider visiting the M125 troubleshooting page before replacing the part: Logitech M125 Troubleshooting
Be sure to unplug your mouse before proceeding with this guide.
Neye ihtiyacın var
Turn the device over and remove the two 0.5mm screws near the front of the mouse by using a Phillips #0 screwdriver.
Once the screws are removed, open the mouse from the front as it pivots at the rear.
There are two tabs that further secure the mouse buttons to the frame. They are located on either side of the mouse cord retracting mechanism.
To dislodge the tabs, use a prying tool while pressing down on the back of the mouse. When prying, push the tab towards the outside of the mouse.
Using a Phillips #0 screwdriver, unscrew the three black 0.5mm screws from the frame to remove the power cord housing
Set mouse plate aside after unscrewing the cord housing from the plate
