Ana içeriğe geç
Logitech M125 Power Cord Replacement
Neye ihtiyacın var
  1. Logitech M125 Power Cord Replacement, Button Plate: adım 1, 3 resimden 1. Logitech M125 Power Cord Replacement, Button Plate: adım 1, 3 resimden 2. Logitech M125 Power Cord Replacement, Button Plate: adım 1, 3 resimden 3.
    • Turn the device over and remove the two 0.5mm screws near the front of the mouse by using a Phillips #0 screwdriver.
    • The black screws used in the Logitech M125 frame are all the same size and do not need special consideration for keeping them separated. Silver colored screws are used on the circuit board and have broader heads.
    • Once the screws are removed, open the mouse from the front as it pivots at the rear.
  2. Logitech M125 Power Cord Replacement: adım 2, 2 resimden 1. Logitech M125 Power Cord Replacement: adım 2, 2 resimden 2.
    • Once the mouse is opened, remove the two black 0.5mm screws located towards the back of the mouse. These are the retention screws for the mouse button plate.
    • These screws will also require the Phillips #0 screwdriver.
  3. Logitech M125 Power Cord Replacement: adım 3, 3 resimden 1. Logitech M125 Power Cord Replacement: adım 3, 3 resimden 2. Logitech M125 Power Cord Replacement: adım 3, 3 resimden 3.
    • There are two tabs that further secure the mouse buttons to the frame. They are located on either side of the mouse cord retracting mechanism.
    • The tighter confines of the mouse interior will be easier to navigate with metal prying tools. While plastic tools are preferred for most plastic devices, they are too large to access the left tab in the picture.
    • To dislodge the tabs, use a prying tool while pressing down on the back of the mouse. When prying, push the tab towards the outside of the mouse.
  4. Logitech M125 Power Cord Replacement: adım 4, 2 resimden 1. Logitech M125 Power Cord Replacement: adım 4, 2 resimden 2.
    • To finish removing the button plate, continue lifting the rear of the plate until the tabs have fully left their slots.
    • Once the tabs are clear, push the plate towards the front of the mouse and lift.
  5. Logitech M125 Power Cord Replacement: adım 5, 1 resimden 1.
    • The mouse button plate has now been fully removed. In order to install the replacement, follow the instructions for this guide in reverse.
  6. Logitech M125 Power Cord Replacement, Power Cord: adım 6, 2 resimden 1. Logitech M125 Power Cord Replacement, Power Cord: adım 6, 2 resimden 2.
    • Using a Phillips #0 screwdriver, unscrew the three black 0.5mm screws from the frame to remove the power cord housing
    • Set mouse plate aside after unscrewing the cord housing from the plate
  7. Logitech M125 Power Cord Replacement: adım 7, 3 resimden 1. Logitech M125 Power Cord Replacement: adım 7, 3 resimden 2. Logitech M125 Power Cord Replacement: adım 7, 3 resimden 3.
    • Unscrew the silver 0.25mm screws to remove the circuit board from the mouse base with the same screwdriver.
    • Once unscrewed, remove the circuit board.
    • Circuit board needs to be lifted from the front before being pulled forward to remove it
  8. Logitech M125 Power Cord Replacement: adım 8, 1 resimden 1.
    • The cable is soldered into the board and will require a soldering iron to replace.
    • To continue further, please refer to the following guide on how to solder connectors: How To Solder and Desolder Connections.
    • Follow these steps in reverse to reassemble the mouse.
Sonuç
Bee Pines
97 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Liner Summer 2019 UW Tacoma, Team S1-G2, Liner Summer 2019 üyesi
UWT-LINER-SU19S1G2
5 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
That's a nice guide, thanks :)
Where do you get the replacement cable from?
dC7 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 674
